Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Align data in cells
You can align your data within a cell horizontally and vertically. To do that:
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the More option in the pop-up menu and choosing the Cell menu item,
  3. swipe up to see more options and tap the Text Format option to open the Text Format panel.
    Text Format panel
  4. select one of the horizontal or vertical alignment types:
    • Tap the necessary horizontal alignment type to apply it:
      • tap the Align Left option to line up the text by the left side of the cell (the right side remains unaligned).
      • tap the Align Center option to line up the text by the center of the cell (the right and the left sides remains unaligned).
      • tap the Align Right option to line up the text by the right side of the cell (the left side remains unaligned).
      • tap the Justified option to line up the text by both the left and the right sides of the cell (additional spacing is added where necessary to keep the alignment).
    • Swipe up to see the vertical alignment parameters and tap the necessary type to apply it:
      • tap the Align Top option to align your data to the top of the cell;
      • tap the Align Middle option to align your data to the middle of the cell;
      • tap the Align Bottom option to align your data to the bottom of the cell.
  5. close the cell settings panel by tapping the Close settings panel arrow on the right.
Chiudi
