Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Create lists
To create a list in a text box,
  1. place the cursor to the position where a list will be started (this can be a new line or the already entered text),
  2. open the settings panel by
  3. switch to the TEXT tab and swipe up to see all the settings,
  4. select the list type you would like to start:
    • tap the Bullets option to create an Unordered list with markers and select the marker type,
    • tap the Numbers option to create an Ordered list with digits or letters and select how the list is going to look like.
    Paragraph List settings
  5. close the text settings panel by tapping the Close settings panel arrow on the right.
  6. now each time you press the Enter key Enter key at the end of the line a new ordered or unordered list item will appear. To stop that, tap the Backspace key key and continue with the common text paragraph.
You can also change the text indentation in the lists using the Decrease Indent Decrease Indent icon and Increase Indent Increase Indent icon icons on the TEXT tab.
Chiudi
