Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Change slide background
To customize your presentation, you can change the background fill for each separate slide. To change a background fill:
  1. in the slide list on the left, tap the slide you want to apply the fill to,
  2. open the slide settings panel by
  3. tap the Style menu item,
  4. select the necessary color on the Theme Colors or Standard Colors palette or create your own Custom Color (swipe it up to see more colors),
    Slide Background settings
    1. go to the Add Custom Color menu,
      Custom color
    2. using the color palette, choose the necessary color and select its hue level,
    3. tap the Enabled button to apply the color to the selected autoshape.
    To clear the slide background color, use the No Fill No Fill icon on the Standard Colors palette.
  5. close the slide settings panel by tapping the Close settings panel arrow on the right.
Chiudi
