Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Use the Find function
Search for certain text
  2. tap the Find icon Find and replace option,
    Search panel
  3. if necessary, you can specify search parameters by tapping the Search options icon Search Options icon on the left.
    The Options panel opens. Turn on the necessary switchers:
    Search options panel local
    • Case sensitive - is used to find only the occurrences typed in the same case as your inquiry (e.g. if your inquiry is 'Editor' and this option is selected, such words as 'editor' or 'EDITOR' etc. will not be found).
    When ready, tap the cross icon in the upper left corner.
  4. enter your inquiry into the data entry field,
    Search panel
  5. use arrow buttons to navigate through the found occurrences towards the beginning of the presentation (if you tap the Left arrow button icon) or towards the end of the presentation (if you tap the Right arrow button icon) from the current position.
Replace the found matches
  1. tap the Search options icon Search Options icon on the left to open the Find and replace settings panel,
  2. tap the Find and replace menu item, change the search parameters, if necessary, and tap the cross icon in the upper left corner. The Find panel will change:
    Find and Replace panel
  3. enter the replacement text into the second data entry field,
  4. use arrow buttons to navigate through the found occurrences and tap Replace to replace the currently selected occurrence,
  5. to replace all the found occurrences, tap the Search options icon Search Options icon on the left to open the Find and replace settings panel, tap the Find and replace all menu item and tap DONE. Tap the Replace all caption that appears next to the entry field.
Exit the Find mode
To close the Find panel, tap the Back button on your device.
Chiudi
