Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Select, cut, copy, paste text and objects
Set the insertion point
To position the cursor, touch a text line within the text box.
Pop-up menu local
  • Paste icon Paste previously copied text/object,
  • Delete icon local Delete the next character within the line of text,
  • Edit icon local Edit text (i.e. open the text settings panel),
  • Select the next character,
  • Select all objects on the slide.
Select text and objects
To select an object (shape, image, or chart), tap it. To select a text box, tap its border.
When you select an object, the pop-up menu appears that contains the following options:
Local selection handles
  • Local cut icon Cut the selected text/object,
  • Copy icon Copy the selected text/object,
  • Local delete icon Delete the selected text or object,
  • Local edit icon Edit the selected text or object (i.e. open the text/object settings panel).
Cut, copy, paste text and objects
To cut, copy and paste text passages/objects within the current presentation, use the corresponding options from the pop-up menu that appears when a text passage/object is selected:
  • Cut icon Cut – select a text fragment/object and use the Cut option from the pop-up menu to delete the selection and send it to the clipboard memory. The cut data can be later inserted to another place in the same presentation.
  • Copy icon Copy – select a text fragment/object and use the Copy option from the pop-up menu to copy the selection to the clipboard memory. The copied data can be later inserted to another place in the same presentation.
  • Paste icon Paste – put the cursor within a text box where you want to paste the previously copied text fragment or double-tap the slide where you want to paste the previously copied object and use the Paste option from the pop-up menu. The text will be inserted at the current cursor position. The object will be inserted onto the currently selected slide. The data can be previously copied from the same presentation.
Chiudi
