Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Insert images
Add an image
  1. place the cursor where you want the image to be put,
  3. switch to the Image icon Image tab,
  4. select one of the following options to load the image:
    • the Picture from Library local Picture from library option will open the Media Library where you can select the necessary file.
      You must have appropriate permissions on your device Media Library.
    • the Picture from URL Picture from link option will open the Link settings panel where you can enter the necessary image web address in the Image URL field and tap the INSERT IMAGE button.
The image will be added. Now you can change its properties and position.
Adjust the shape of the image and its border
When the image is selected, the shape settings panel is also available so that you can change the shape of the image as well as adjust its border size and color, if necessary.
  1. select the image by tapping it,
  2. open the shape/image settings panel by
  3. on the Shape tab, tap the Style option, go to the Border style, and switch the Stroke toggle enable or disable border display.
    Tap the Replace section to replace the rectangular shape with another one selected from the menu. The shape of the image will change correspondingly.
    Reshape image
    The Wrap and Reorder sections of the Shape tab allow you to select a text wrapping style from the available ones and set the selected image position as related to other objects when several objects overlap each other.
  4. close the shape settings panel by tapping the Close settings panel cross on the right or use the Return arrow on the left to return to the previous settings section.
Remove the image
Select the image by tapping on it and proceed in one of the following ways:
  • tap the Delete icon local option in the pop-up menu, or
  • open the shape settings panel by tapping the Edit object icon at the top toolbar, then use the Remove shape button at the Shape tab.
Chiudi
